Které disky sluší novému Focusu II ?
zirafak
Re: Které disky sluší novému Focusu II ?
8x18 et 35...je mozne,ze bude problem so suchanim o lem blatnika..osobne by som volil vyssie ET.
- bee
zirafak
pekne,pekne...akurat tie krytky VRC mi tam velmi nesedia
- bee
Snad tam budu pasovat aj krytky s logom fordzirafak píše:pekne,pekne...akurat tie krytky VRC mi tam velmi nesedia
Ale aj tieto sa mi celkom pacia
- misoo
Re: Které disky sluí novému Focusu II ?
nefunguje mi ten link
- bee
No badám od posledného víkendu, ze sajta má nejaký problém s PHP-čkom, admini (IT) by sa na to mali pozrieť... ja mam v browseri furt nejake chyby vypisane...misoo píše:nefunguje mi ten link
A nedostanem sa ani do vlastného albumu
0
Fatal error: Call to undefined function img_link() in /usr/home/focus/public_html/forum/cache/tpl_etech_partners_468.inc.php.php on line 18
alebo:
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /usr/home/focus/public_html/forum/cache/tpl_etech_breadcrumbs.html.php:5) in /usr/home/focus/public_html/forum/cache/tpl_etech_partners_468.inc.php.php on line 3
0
- victor
jj ja mam podobne vzdy pri postovani noveho prispevku
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /usr/home/focus/public_html/forum/cache/tpl_etech_breadcrumbs.html.php:4) in /usr/home/focus/public_html/forum/cache/tpl_etech_partners_468.inc.php.php on line 3
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /usr/home/focus/public_html/forum/cache/tpl_etech_breadcrumbs.html.php:4) in /usr/home/focus/public_html/forum/cache/tpl_etech_partners_468.inc.php.php on line 3
- bee
ok, tak pridám externý album:
http://picasaweb.google.sk/babeliak/Alu_focus_ST
- misoo
ten druhy link fachci. takze dalsi "st"-ckar ? pekne pekne
- Jackel
A co ty Dotz Hanzo 8x17" ET35 a pneu 225/45 R17 půjdou na focuse nebo ne? Nějaká zkušenost?
TripleJay
No nemam prakticke skusenosti, ale myslim ze na Focus II je limit na ET tak 40-42, moozno 38. Ale 35, to je uz dost, asi by to uz pytalo upravit lemy blatnikov. Ak si ochotny ich upravovat (nie je to nejak narocna uprava), tak kludne mozes ist aj do ET35.
- Merdy
Chlapi já jsem z toho zmatený. Pro vysvětlení si vezměme Misoo-a a Milinka.
Oba mají na svých focusech origo kola s ET 52,5 - důležitá informace, že ET je v milimetrech.
Poté si oba namontují na nápravy podložky, čímž defacto sníží ET o rozměr podložek. Takže mají-li podložky 20mm na přední nápravě a 30mm na zadní, dostaneme ve výsledku ET 32,5 vpředu a ET 22,5 vzadu. To znamená, že kdyby neměli podložky, tak by potřebovali výše zmíněné ET disků, aby dosáhli stejného efektu zarovnání disků s blatníkem.
Takže jak potom chodíte na názory, že ET 35 je pro focus hranice
- Milinko
Mno, dobrá otázka...já myslím,že těch 35 je hranice pro šířku ráfku 7 palcůMerdy píše:Chlapi já jsem z toho zmatený. Pro vysvětlení si vezměme Misoo-a a Milinka.
Takže jak potom chodíte na názory, že ET 35 je pro focus hranice![]()
Opravte mě jestli se pletu, rád bych věděl jak to je...
BTW: Já a misoo máme napředu 2.5cm a vzadu 3cm, 6.5 palcu ráfek.
zirafak
Presne tak...sirka disku v palcoch tam hra dolezitu ulohu
Osobne uz vidim misoo-ve a milonko-ve 2,5 predo a 3 zadok dost extrem.Ja som mal kedysi na 17-tkach 1,5 predok a 2,0 zadok.Ideal povazujem 2,0 predok a 2,5 zadok.
- Milinko
Extrém to možná je trošku, za dobu co to mám jsem škrtl jen v případě že jsem vezl 4 chlapi a plný kufr, jinak bez problémů...zirafak píše:Presne tak...sirka disku v palcoch tam hra dolezitu ulohu![]()
